Forum Header
No Step pulses on any step axis
- purwanu
06 Feb 2010 10:37 #1785
by purwanu
No Step pulses on any step axis was created by purwanu
I have installed successfuly the EMC, the latency-test give very nice result on the maximum jitter, it gave around 11000. After StepConf wizard, I noticed there is no pulses coming from the parallel port, the control direction signal is working fine. In my setup, I put all pin into "Unused" except the XYZ Step and Direction.
Have I missed something? I am new to EMC2...
Regards,
Purwanu
Regards,
Purwanu
- BigJohnT
- Thank you received: 1176
06 Feb 2010 13:03 #1786
by BigJohnT
Replied by BigJohnT on topic Re:No Step pulses on any step axis
You might try and open the HAL Configuration window from Axis and watch the parallel port pins while you jog each axis real slow to see if EMC is generating the pulses.
- purwanu
06 Feb 2010 14:37 #1788
by purwanu
Replied by purwanu on topic Re:No Step pulses on any step axis
Hello,
I tested the xstep pinout, with HALScope, there were pulses. I found that 1K resistor series with the optocoupler was too big. So without that resistor, now the step pulses has driven the L297 nicely..
Thanks...
Purwanu
Thanks...
Purwanu
Time to create page: 0.097 seconds
