Forum Header
Backlash??
- conicio
05 Jun 2012 15:50 #20663
by conicio
Backlash?? was created by conicio
After updating from emc2 to linuxcnc I have an issue on my Z axis. It travels i.e. 10 mm in one direction and 7 in the other. I know this is due to a backlash inherent to the trapezoidal thread. Where can I find to fix a backlash problem that I've got with the z axis?
I'm getting stuck
looking around int the stepconf wizard, the .ini and I can't find it.
Help please
I'm getting stuck
Help please
- cncbasher
- Thank you received: 288
05 Jun 2012 16:06 - 05 Jun 2012 16:06 #20665
by cncbasher
Replied by cncbasher on topic Re:Backlash??
add BACKLASH = x to the axis[2] section of the ini
x = amount of backlash required
Last edit: 05 Jun 2012 16:06 by cncbasher.
- BigJohnT
- Thank you received: 1176
05 Jun 2012 16:14 #20666
by BigJohnT
Replied by BigJohnT on topic Re:Backlash??
There is a bit more to adding backlash compensation.
Please read the backlash section of the Integrators manual.
- conicio
05 Jun 2012 17:39 #20667
by conicio
Replied by conicio on topic Re:Backlash??
Thanks I'll try it.
- Thank you received: 4994
06 Jun 2012 12:37 #20675
Replied by andypugh on topic Re:Backlash??
conicio wrote:
3mm backlash seems very unlikely. Do you actually have 3mm of thread pitch? I would imagine that 3mm of wear in the nut would convert it onto a tube...
Normally the weight of the knee or head takes up the Z backlash anyway.
