Forum Header
parallel port settings for Probotix meteor
- rmattioda
16 Nov 2012 01:06 #26636
by rmattioda
parallel port settings for Probotix meteor was created by rmattioda
i am new at Linux cnc.
when i use the configuration wizard to make a new profile, then open the file 1 y motor will not work.
when opening the old configuration everything works fine. how do I view these settings it will not allow the view when you select the modify another file at the beginning of the wizard.
- BigJohnT
- Thank you received: 1176
16 Nov 2012 08:55 #26651
by BigJohnT
Replied by BigJohnT on topic parallel port settings for Probotix meteor
When you select edit a config you have to select the .stepconf file you wish to edit.
Time to create page: 0.106 seconds
