× Forum Header
TB6560: "Digital out 0" vs "Amplifier Enable X"?
15 Jan 2013 00:13 #28686 by awes
just started to RongFu-30 mill conversion.
Have the "Chinese Blue" card with some 270oz 3A steppers. Running a 12:30 gearing.
Only got x-axle to work so fare.
But here is my question:
Several posts in this forum suggest to map "X Enable" to "Amplifier Enable X" (etc) while I found a youtube clip where a guy map "X Enable" to "Digital Out 0" (and invert the signal).
The last setting is what I have currently and it works.
So an explanation pros&cons for the two alternative settings would be much appreciated.
Regards
Anders Westberg
Spånga
Sweden
19 Jan 2013 05:04 #28809 by awes
OK,
obviously nobody has an answer.
But could somebody pls point me to where in the documentation "digital out" and "amplifier enable" are described so I can read up on it myself?
Anders
Sånga
Sweden
19 Jan 2013 19:32 #28818 by cncbasher
Replied by cncbasher on topic TB6560: "Digital out 0" vs "Amplifier Enable X"?
digital out is used to be able to configure a charge pump to that pin , rather than just an enable function
some tb6560's do not have a charge pump circuit , so an enable is all that's required
their are at least 4 versions of these boards that I am aware of , and each one uses a different pin configuration and other options
although it would seem the blue boards are becoming more prolific
20 Jan 2013 04:47 - 20 Jan 2013 04:51 #28845 by awes
Thank you very much for that info!
"field testing"
Tried to change to "enable" from "digital our" and my y-axis stopped working. (in interestingly x and z did function as expected, only y stopped working)
So I would say that for my card pros/cons are obvious. Enable does NO work, Digital out does......
Anders
Last edit: 20 Jan 2013 04:51 by awes. Reason: added info
20 Jan 2013 19:01 - 20 Jan 2013 19:35 #28862 by cncbasher
nice to know that , it seems the Blue Boards have Chargepump style circuit so need a digital pin ,
could you post your hal & ini file and i'll see if i can document further my database of these board styles
are their any version number on the pcb that may help identify further perhaps , and or do you have a link to the documentation specific to your board available .
i'm hopfull that we can add this to stepconf as a menu option , their are quite a few forum questions popping up for these
but covering all revisions of these boards is difficult , as i have found even the supplied documentaion although sparse , also to be incorrect .
so i am trying to build up a FAQ and document these
Last edit: 20 Jan 2013 19:35 by cncbasher.
21 Jan 2013 01:26 #28886 by awes
Happy to share my ini and hal files as well as link to the documentation. Unfortunately I forgot to copy them before I left the garage. Will try to fix it later this week.
11 Feb 2013 06:38 #29877 by awes
Was going to provide my files but "Add files" doesn't work for me :-(
11 Feb 2013 16:38 - 15 Feb 2013 17:44 #29896 by cncbasher
Awes has kindly forwarded the files to me
for the time being if anyone requires these files , then let me know by email and i'll forward
untill such times as the forums fixed ..
file is now on the Wiki
thanks
Last edit: 15 Feb 2013 17:44 by cncbasher.
11 Feb 2013 22:25 - 11 Feb 2013 22:27 #29907 by BigJohnT
Add Files is broken for everyone until the forum software is brought up to current... It's above my pay grade so all I can do is whine like a little girl till it is upgraded.
Last edit: 11 Feb 2013 22:27 by BigJohnT.
Time to create page: 0.058 seconds
