Forum Header
default HOME_SEQUENCE output
- SrLange61
- Thank you received: 5
15 Jun 2013 08:57 #35663
by SrLange61
default HOME_SEQUENCE output was created by SrLange61
In stepconfig I haven't seen any setting for homing order ?
It just defaults a HOME_SEQUENCE were the Z axis goes first followed by x then y.
Can this be fixed in the stepconf settings file?
I've just installed a new driver so using stepconfig it is more easier to find the best settings than having to edit the .ini
srl
srl
- cncbasher
- Thank you received: 288
15 Jun 2013 15:03 #35670
by cncbasher
Replied by cncbasher on topic default HOME_SEQUENCE output
stepconf as well as pncconf are just a starting point , you need to hand edit the ini file
by changing HOME_SEQUENCE =
