- Configuring LinuxCNC
- Configuration Tools
- StepConf Wizard
- Parallel port check - Modules:parport -parport_pc
Forum Header
- adelabarra
16 Jun 2013 06:39 - 16 Jun 2013 06:40 #35700
by adelabarra
Parallel port check - Modules:parport -parport_pc was created by adelabarra
Hello everybody!
I´ve just read the conditions and realized that a "new topic" was the right way to post. I am new to the forum.
I've just "succeeded" on installing emc2-2.4.5 with RTAI 3.3 and Slackware kernel 2.6.10 with r12 patch.
But there is a problem about parallel port configuration.
When I try to run the "ptest.hal" I receive by dmesg:
insmode parport_pc failed:
Unknown symbol parport_ieee1284_ecp_read_data
Unknown symbol parport_ieee1284_epp_read_data
Unknown symbol parport_ieee1284_ecp_read_nibble
From that I made some hacking and found that if I insmod the "parport"
module it seems to work but don't know if it really does, because when I test the pins nothing happens.
Do I have to recompile the kernel with the "ieee1284" as Module?
Do I have to check first if my port is open collector? (Because if I don't insert the resistance nothing should happen¿?)
Do I really need to insert the "parport" module to insmod the parport_pc or is there another better module instead?
I'm Sorry... there is a lot of questions.
Regards.
Alejandro.
Regards.
Alejandro.
Last edit: 16 Jun 2013 06:40 by adelabarra.
- ArcEye
- Thank you received: 758
16 Jun 2013 16:13 - 16 Jun 2013 20:06 #35703
by ArcEye
Replied by ArcEye on topic Parallel port check - Modules:parport -parport_pc
Hi
Why do you want to load parport_pc?
Linuxcnc has its own module hal_parport which handles the parallel port
If you try to load parport_pc, lp and ppdev, linuxcnc will not work
What I think you have done is tried to run the parallel port tester, whilst the parport is already claimed by parport_pc, which should not be loaded
Check /etc/modules does not have the line
lp
in it
Also that /etc/modprobe.d/linuxcnc.conf (or emc.conf) has the line
install parport_pc /bin/true
uncommented
What is unclear is why you ran the parallel port test at all.
Are you unable to run a config in Linuxcnc?
lp
in it
uncommented
Last edit: 16 Jun 2013 20:06 by ArcEye.
- adelabarra
16 Jun 2013 21:19 #35709
by adelabarra
Replied by adelabarra on topic Parallel port check - Modules:parport -parport_pc
Dear Arc:
Thanks for your answer!!
Last night I became obsessed with the problem until 4:30 AM.
The problems were:
Q: ¡Where the heck is my f*** parallel card?
A: My PC seen it as 16550 serial controller! - I found that on an Ubuntu forum.
I have also an embedded port that was detected as Printer, with 378 address. So I was sending bytes to the sky!!!
Q: What was my card address?
A: lspci -v => 0x1440; 0x1448 - Now it doesn't appear any more as 16550 serial controller.
"What I think you have done is tried to run the parallel port tester, whilst the parport is already claimed by parport_pc, which should not be loaded"
OK. The halrun tries to load the parport_pc. If "parport" is not lodaded it fails. What I didn't know was if it was a problem about "parport"
Finally I downloaded a little C program and checked the port an runned successfully.
Now I'll try with the ptest.hal
Regards!
Alejandro.
The problems were:
Regards!
Alejandro.
- adelabarra
16 Jun 2013 21:41 #35710
by adelabarra
Dear Arc:
Finally I succeeded on testing the F*****************************************! port!!!!!!!!!!!!!!!
The ptest.hal works as intended. I also found 4 pins as inputs: 10, 11, 12, 13 and 15.
No I'll try to mount the hardware.
Here today is the "father's day". It is the best gift I could receive.
Regards
Alejandro.
Regards
Alejandro.
- ArcEye
16 Jun 2013 21:53 #35712
by ArcEye
Glad you sorted it out
Be aware that the LED lighting on the port tester means nothing unless there is a corresponding voltage at the pin in question.
But from what you wrote earlier I am sure you realise that
- adelabarra
16 Jun 2013 23:40 #35719
by adelabarra
Hello!
When I made the first tries the measures had nothing to see with the colors I saw in the leds.
Also I had to cut the cable and mount everything on a proto-board to be sure of the measures.
I was just to blame your program and post: "Hey! where did you get that colors from!"
I was lucky not to post that!!
I would be banned from the forum...
The result of the measuring was:
0.0 V Red
5.14 V Green
Regards,
Alejandro.
0.0 V Red
5.14 V Green
Regards,
Alejandro.
- Thank you received: 4989
17 Jun 2013 08:21 #35728
wiki.linuxcnc.org/cgi-bin/wiki.pl?UpdatingTo2.5
Replied by andypugh on topic Parallel port check - Modules:parport -parport_pc
You seem to be a bit behind in your LinuxCNC version. An upgrade to 2.5.2 should be fairly straightforward, but needs to be forced.I've just "succeeded" on installing emc2-2.4.5 with RTAI 3.3 .
- adelabarra
17 Jun 2013 09:15 - 17 Jun 2013 18:42 #35730
by adelabarra
Hello!
For now i'll mount all the stuff. Try the motors, the HY-TB5DV_M_5Axis interface, mount the structure and so on.
Later I'll try the new versions.
I connected a little ear-phone on the output and heard the pulses.(!)
Alejandro.
Alejandro.
Last edit: 17 Jun 2013 18:42 by adelabarra. Reason: Typo
- StepConf Wizard
Time to create page: 0.069 seconds
