- Configuring LinuxCNC
- Configuration Tools
- StepConf Wizard
- Questions about timing and Latency Tests HobbyCNC
Forum Header
- blitz355
10 Jul 2013 07:27 - 10 Jul 2013 09:46 #36478
by blitz355
Questions about timing and Latency Tests HobbyCNC was created by blitz355
Switching from Mach 3 to LinuxCNC.
Specs
Driver: HobbyCNC ez driver (uses same driver chip as the PRO version)
PCI parallel port
dual core amd system ~2.4ghz 4gb ram
linuxcnc installed via wubi
First question,
during the stepconf wizard you have to choose timings for your driver board, I had no clue what mine were as these timings aren't listed on the HobbyCNC website that i know of. So I chose the HobbyCNC pro preset (my board is the HobbyCNC ez driver not the pro). Will these presets for the PRO board be okay for my ez driver board? I tested the motors with this setting and it all seems to work fine. Is there any way to test to make sure its fine? Also, what do these timings actually effect?
Second.
I did the latency test and my reading is like 75 percent over the recommended range (~20000-50000). Mine was going up past 100,000. However, again the motors seemed to jog fine and i even ran a program in the air. All seemed fine.
Is there any dangers to my machine/driver board/computer if i run with these settings?
Specs
PCI parallel port
First question,
Second.
Last edit: 10 Jul 2013 09:46 by blitz355.
- emcPT
- Thank you received: 139
10 Jul 2013 13:12 #36481
by emcPT
1st) The timing should be ok. If not mistaken, the timing will reflect the maximum pulse rate.
2nd) That PC is not good for linuxcnc. What can happen is a "glitch" during a job, something random as for a instant, linuxcnc could not output the desired steps into the parallel port, and this is something that you do not want. My latest PC had a max of 7500.
Replied by emcPT on topic Questions about timing and Latency Tests HobbyCNC
First question,
Second.
- ArcEye
- Thank you received: 758
10 Jul 2013 17:52 #36494
by ArcEye
Replied by ArcEye on topic Questions about timing and Latency Tests HobbyCNC
Hi
100K base thread is not usable as emcPT says
You need to be very clear as to whether these are occasional spikes or a constant high figure
Have a read of these to see the problem and some possible solutions
www.linuxcnc.org/index.php/english/forum...-the-latency-problem
www.linuxcnc.org/index.php/english/forum...me-latency-solutions
I would start by looking hard at the graphics driver / card and disabling the second core if possible
I don't know if AMD uses hyperthreading or if that is just Intel, there is certainly no SMI isssue, that just affects some Intel chipsets.
Any power saving / management in BIOS that can be disabled needs looking at.
- blitz355
10 Jul 2013 22:59 #36518
by blitz355
I will be sure to look into those links and try to remedy the issue.
As I'm typing the test is running for about 5 minutes now and the base thread max jitter (that is the value I'm supposed to look at right?) hasn't gone past 13,441ns (is this the number i put in the stepconf wizard?). Which is good. not sure what made the values go that high yesterday.
Replied by blitz355 on topic Questions about timing and Latency Tests HobbyCNC
Hi
- ArcEye
10 Jul 2013 23:16 - 11 Jul 2013 14:43 #36519
by ArcEye
Yes it is base thread max jitter, but you need to run for a lot longer than that.
The figure shown is a cumulative one, which means one high spike and the whole test is high.
The first FAQ shows how to do a rtai latency test from the command line, which does a per second reading and should assist seeing what is going on if you get a high reading again.
Last edit: 11 Jul 2013 14:43 by ArcEye.
- StepConf Wizard
Time to create page: 0.072 seconds
