- Configuring LinuxCNC
- Configuration Tools
- StepConf Wizard
- Base Period Maximum Jitter -> max number is 50000?
Forum Header
- nquantum
14 Jul 2013 23:44 #36644
by nquantum
Replied by nquantum on topic Base Period Maximum Jitter -> max number is 50000?
from gigabyte web GA-E350 have 3 version.
www.gigabyte.com/products/list.aspx?s=42&jid=16&p=2&v=25
also from latency test is use GA-E350 rev.3
Which one u use? Also GA-E350 rev.3 correct?
- emcPT
- Thank you received: 139
16 Jul 2013 04:42 #36685
by emcPT
Replied by emcPT on topic Base Period Maximum Jitter -> max number is 50000?
I am at home and the board/manual is in my workshop.
The board was ordered here:
www.alientech.pt/product_info.php?manufa...d=&products_id=20816
The site is in Portuguese but the specifications are all in English.
Looking at the revision differences I could not find any, so all the important stuff is the same, so both should work ok.
- emcPT
16 Jul 2013 14:11 #36695
by emcPT
I was just checking on the board itself and mine is review 1.0
Newer should be better as normally only small changes are made.
- nquantum
17 Jul 2013 01:30 #36721
by nquantum
Thank you. I also miss read your earlier post. It's GA-E350N WIN8.
I've order from Amazon. Now waiting for it to come.
- StepConf Wizard
Time to create page: 0.274 seconds
