Forum Header
StepConf Axis Test not working
- abrambleninja
16 Aug 2013 09:33 #37727
by abrambleninja
StepConf Axis Test not working was created by abrambleninja
Hello,
I was configuring StepConf for my CNC machine, and I ran into a tiny bit of trouble. First, I just changed the minimum I needed to in order to get the motors to work (with outputs and things), and I have that figured out now. So, I did that, and the machine works for manual control. However, I then went back to try and configure it to work better (and tell it how many rotations were 1inch and so on). So, I'm on the X Axis Configuration page, and I haven't changed anything from the defaults. I clicked on Test This Axis to figure out some of the things I need to change for it to work better, and messed with all the settings there, and I just can't get it to move at all. I went to the LinuxCNC documents, and followed the instructions there for the "Test This Axis" pane, and I still can't get it to move.
To quote the documentation for this,
Does anyone have any suggestions?
Thanks!
The thing is, my machine works under manual control, just not in the stepconf program. I can't figure out why this is.If the machine doesn't move, stalls, or loses steps no matter how low you turn Velocity, verify the following:
Correct step waveform timings
Correct pinout, including "Invert" on step pins
Correct, well-shielded cabling
Physical problems with the motor, motor coupling, leadscrew, etc.
Thanks!
- Rick G
- Thank you received: 155
16 Aug 2013 14:01 #37729
by Rick G
Replied by Rick G on topic StepConf Axis Test not working
Does your driver use an amp enable signal and or charge pump? Have you tried inverting the signal?
Rick G
Rick G
- cncbasher
- Thank you received: 288
16 Aug 2013 14:13 #37730
by cncbasher
Replied by cncbasher on topic StepConf Axis Test not working
test axis is simplified for minimal use , and has no control of IO so if you have Amplifier enable connected it will not work , so while using stepconf disconnect Amplifier enable .
- abrambleninja
17 Aug 2013 01:25 #37761
by abrambleninja
My driver board doesn't use either amplifier enable or charge pump. Here's the driver documentation. I can post my stepconf/HAL files if you want.
Replied by abrambleninja on topic StepConf Axis Test not working
- cncbasher
17 Aug 2013 02:16 #37765
by cncbasher
the tb6560's are well documented on the forum , enable x,y,z is amplifier enable in Linuxcnc ,
do you have any errors popping up ?
stepconf is realy just for initial setting up , after that it's best to hand edit the files .
post your hal and ini files as attachments is a good idea if your stuck
The following user(s) said Thank You: abrambleninja
- abrambleninja
17 Aug 2013 02:55 - 17 Aug 2013 02:56 #37767
by abrambleninja
Thanks!
Edit: I forgot a word.
Oh, I see. I added some things to custom.hal to get enable x,y, and z. I didn't realise that it was amplifier enable.the tb6560's are well documented on the forum , enable x,y,z is amplifier enable in Linuxcnc
Not in either the test axis window or the LinuxCNC main page.do you have any errors popping up ?
Oh, ok. I guess I have to figure out what they all mean.stepconf is realy just for initial setting up , after that it's best to hand edit the files .
I attached a ZIP of the entire directory (along with the .stepconf file) because I'm not sure how much to post.post your hal and ini files as attachments is a good idea if your stuck
Thanks!
Last edit: 17 Aug 2013 02:56 by abrambleninja.
- cncbasher
17 Aug 2013 15:17 - 17 Aug 2013 15:20 #37777
by cncbasher
in your INI file
under [TRAJ] you have a low default Velocity of 0.15 change it to say 5.0
you'll probably end up having the velocity and acceleration higher , once you start tuning ..
remember when running stepconf it will change settings when you save the file .
i usualy make a dummy config to tune with and then transfer the settings to a working config manualy or when adding options , that way you dont loose any previous .
to disable the enables in your custom file while you use stepconf ..
just place a # at the beginning of the lines , then uncomment when your finished with stepconf .
Last edit: 17 Aug 2013 15:20 by cncbasher.
Time to create page: 0.058 seconds
