× Forum Header
Driver Timing Settings - Need Help
05 Sep 2013 09:15 #38479 by kb9jlo
Driver Timing Settings - Need Help was created by kb9jlo
I have an ancient CNC controller. It's been waiting a long, long time to be hooked up and working at something. I'm building a MyDIYCNC type of machine. I'm using NEMA 23 stepper motors, unipolar and the controller is a CW Technology that uses Allegro UCN5804B driver chips.
I've attached a piece of the data sheet, showing the timing diagram. What all information do I need to input into LinuxCNC?
Can someone help please?
I tried comparing the timing diagram to the L297 diagram but I just couldn't figure it out...
If it's not too much trouble I'd like to know how to translate this data to get the information you need.
KB9JLO
05 Sep 2013 13:49 #38481 by cncbasher
Replied by cncbasher on topic Driver Timing Settings - Need Help
I would start with something in the order of
step time 30000
step space 100000
direction hold 4000
direction setup 4000
that should at least get you in the ball park ,
The following user(s) said Thank You: kb9jlo
05 Sep 2013 21:30 - 14 Sep 2013 09:37 #38491 by kb9jlo
Replied by kb9jlo on topic [Solved] Driver Timing Settings - Need Help
Thank you very much. I was working on setting up my LinuxCNC machine last night. I'm anxious to try out the PC side of things and my X axis is nearly done and I'm hoping to see it move...
I may actually build a working CNC this time.
Last edit: 14 Sep 2013 09:37 by kb9jlo. Reason: mark as solved
Time to create page: 0.048 seconds
