- Configuring LinuxCNC
- Configuration Tools
- StepConf Wizard
- Steppers work in StepConf but not in LinuxCNC
Forum Header
- buffington
25 May 2014 02:12 #47292
by buffington
Steppers work in StepConf but not in LinuxCNC was created by buffington
I was able to tune my steppers in StepConf without issue, but when trying to do any operation where I'd expect the steppers to move in LinuxCNC I get no movement.
My setup uses a 5 axis parallel port breakout board connected to 3 TB6560 drivers (I'm only using 3 of the 5 axises for now). I have a single emergency stop button hooked up and have verified that its works (the Estop in LinuxCNC button toggles as expected).
Am I missing something fundamental?
- ArcEye
- Thank you received: 758
25 May 2014 20:11 #47308
by ArcEye
Replied by ArcEye on topic Steppers work in StepConf but not in LinuxCNC
Hi
The TB6560 boards are troublesome, mostly because there are lots of different versions, some with different pin outs.
Look at the enable pins, they must be powered before anything will move and are a common source of problems.
If you search the forum with TB6560, you will find several threads, some with similar problems.
In at least one case the enable signal had to be inverted to work
- buffington
27 May 2014 03:44 #47369
by buffington
Replied by buffington on topic Steppers work in StepConf but not in LinuxCNC
I solved the problem.
I appears that while in StepConf, the steppers are somehow told to turn on even when the "Amplifier Enable" pins haven't yet been set.
When using Axis, the steppers won't move unless the enable signal is sent - if the pins to do that haven't been assigned then they'll remain off despite best efforts to turn them on while in Axis.
I combed through my config and triple checked my wiring a few times before I realized that the Amplifier Enable pin wasn't assigned properly. Once assigned, everything worked.
- StepConf Wizard
Time to create page: 0.048 seconds
