Forum Header
configuration DM542A
- jnbatisse
02 Jul 2015 04:40 #60317
by jnbatisse
configuration DM542A was created by jnbatisse
- ArcEye
- Thank you received: 758
02 Jul 2015 13:19 - 02 Jul 2015 17:46 #60330
by ArcEye
Replied by ArcEye on topic configuration DM542A
No exact match on the chart, but the nearest size digital one should give an idea.
wiki.linuxcnc.org/cgi-bin/wiki.pl?Stepper_Drive_Timing
PS
By which I mean, these are Leadshine knock offs, so you can use their timings as a base
2500
2500
10000
8000
should be a good start, the dir times in particular are always longer and trying to cut them down adds nothing to stepper speed but risks ending up with steppers
that only go in one direction or sometimes do not change direction as required.
PS
2500
2500
10000
8000
Last edit: 02 Jul 2015 17:46 by ArcEye. Reason: clarify
- Thank you received: 3821
02 Jul 2015 17:46 #60336
Replied by rodw on topic configuration DM542A
Thanks, just getting going and heve the DM542a stepper controllers.
- ArcEye
02 Jul 2015 17:48 #60337
by ArcEye
If you refresh your page I added a bit more info to my reply whilst you were posting
02 Jul 2015 18:00 #60338
Thanks, I know the 542a is an improved version of the 542 but not sure what was improved. They look identical.
Time to create page: 0.126 seconds
