× Forum Header
How to set a bit in the paralell port
08 Dec 2015 11:50 #66635 by Fredrik2556
How to set a bit in the paralell port was created by Fredrik2556
Hi
I want to set a bit in the parallell port to a permanent high, it is connected to the enable on all steppet drivers. How do I do it, is it possible?
Best regards
Fredrik
08 Dec 2015 14:02 #66640 by Todd Zuercher
Replied by Todd Zuercher on topic How to set a bit in the paralell port
Hi
Best regards
Fredrik
The most basic way would be a setp in your hal file (for pin 6 on the first port)
setp parport.0.pin-6-out  true
If you'd rather it change state, say with e-stop or machine power on, then connect it to one of those pins instead.
Time to create page: 0.076 seconds
