Forum Header
Can't get stepper motors to move at all
- mpayne
27 Jan 2018 20:58 #105078
by mpayne
Can't get stepper motors to move at all was created by mpayne
First, thanks for taking the time to read my post. I’ve really tried to solve this on my own but I’m getting nowhere
I’m moving my CNC setup from a (very old) PC running Windows XP, Mach3 and a MX3660 to a new PC with a fresh install of LinuxCNC 2.7. I’m using the same MX3660 and the new PC has a PCIe parallel port card. The card is a SD-PEX10005 which is a netMOS 9900 chip. The system works on my XP machine
My problem is I cannot get any of the stepper motors to move. My parallel port is working because my E-STOP works in linuxCNC. I can press the button and LinuxCNC goes into stop mode. When I release the button it exits stop mode.
When I jog in LinuxCNC the display shows the spindle moving the correct direction, but my CNC machine is motionless.
I’ve tried running the step config many times trying different things, using my Mach3 XML file and using new config. I tried adding my user to the LP group in case it is a permissions problem. Nothing is working. I’ve read through the posts here and tried just about anything I can find. I’m out of ideas to try. Can anyone suggest something I can do to figure out the problem?
Thanks for your help,
Mike
Mike
- Clive S
- Thank you received: 486
27 Jan 2018 21:37 #105079
by Clive S
Replied by Clive S on topic Can't get stepper motors to move at all
It would help if you uploaded your |Hal and Ini files from the config folder. It might be that the drives are not enabled.
- mpayne
27 Jan 2018 21:51 #105081
by mpayne
Replied by mpayne on topic Can't get stepper motors to move at all
Thanks for the reply. Here are the INI and HAL files. Thanks!
- Thank you received: 5329
27 Jan 2018 22:04 - 27 Jan 2018 22:12 #105082
Replied by PCW on topic Can't get stepper motors to move at all
You might try doubling the step lengths to 3000 ns (3 usec) = the "reset time"
1500 ns is too fast for the MX3660
The MX3660 specs say 2500 ns minimum step length
( and minimum means on the edge of not working... )
Edit:
Also the MX3660 manual says this:
"If step & direction signal voltage is lower than 5 VDC, you may need to increase step
width and direction setup time (> 5 uS) to move your motors, or avoid loss of step."
Pretty sure the NetMOS 9900 is s 3.3V chip so you may need a reset time of 5000 ns
Edit:
Last edit: 27 Jan 2018 22:12 by PCW.
- mpayne
27 Jan 2018 22:49 #105086
by mpayne
I tried increasing the times and still no movement. Here is the new HAL file that was generated
27 Jan 2018 22:55 #105087
You might try disabling the chargepump logic on the MX3660 just in case theres an issue with it
- mpayne
27 Jan 2018 23:16 #105088
by mpayne
That did it! Thank you so much for your time.
- Clive S
27 Jan 2018 23:18 #105089
by Clive S
Glad you got it working.
