- Configuring LinuxCNC
- Configuration Tools
- StepConf Wizard
- Setting up a gantry with 4 joints and 3 axes
Forum Header
- DanMN
- Thank you received: 10
26 Mar 2018 01:42 #107874
by DanMN
Replied by DanMN on topic Setting up a gantry with 4 joints and 3 axes
Home All doesn't work?
- Abe
26 Mar 2018 01:52 #107875
by Abe
Replied by Abe on topic Setting up a gantry with 4 joints and 3 axes
Ah, so that's what actually links the joints! Yes, counterintuitive for sure. I think my INI (attached) now conforms to these suggestions, and I'm getting the error message I mentioned in my last post, along with there being no option to home the Y axis in Machine>Homing.
Thanks,
Abe
Thanks,
Abe
- DanMN
26 Mar 2018 01:53 #107876
by DanMN
Are you using Axis? Do you not see a Home All button?
- DanMN
26 Mar 2018 02:02 #107877
by DanMN
Just noticed, you don't have any entry under TRAJ for homing.
I have:
NO_FORCE_HOMING = 1
See if that has any effect. I'm not clear how it might affect the homing sequence in your case, but that's the way mine is configured. That allows me to jog the Z and X axes before the gantry is squared -- which is helpful if a joint ends up on a limit switch during configuration fiddling (which is your future, soon)
I have:
NO_FORCE_HOMING = 1
- Abe
26 Mar 2018 02:08 #107878
by Abe
Yes, home all does get the gantry moving! There's some issue with my homing switches not being heard, but I will see about sorting that out.
Thanks so much!
Thanks so much!
- Abe
26 Mar 2018 02:11 #107879
by Abe
Sorry, I've posted a reply without seeing your latest post a couple of times. I'll try the force homing thing, too, and let you know what happens.
- Thank you received: 4149
26 Mar 2018 03:15 #107886
Abe, this is expected. You need to home all and after that you'll be able to jog your Y axis.
This is because now the joints (eg motors) are now independent from the Axes and homing is at a joint level. You can't jog a joint on a gantry on its own as it will rack the gantry. Once everything is homed, it knows about the way your hardware is configured so it can jog.
Replied by rodw on topic Setting up a gantry with 4 joints and 3 axes
Thanks, Todd. I set HOME_SEQUENCE = -2 on joints 1 and 3 in the INI file, and now when I try to jog the Y axis it says "Homing is REQUIRED to jog requested coordinate because joint (1) in home_sequence is negative (-2)". There is still no option to home the Y axis in the Machine>Homing menu.
Thanks,
Abe
- StepConf Wizard
Time to create page: 0.504 seconds
