× Forum Header
Error stepconfig for lathe
22 May 2018 19:45 #111034 by Aleks
Error stepconfig for lathe was created by Aleks
When creating a new configuration, the module Stephen.2..... in the hal file causes an error.
24 May 2018 14:44 #111082 by andypugh
Replied by andypugh on topic Error stepconfig for lathe
Which version of LinuxCNC?
I assume you mean "stepgen.2..."
24 May 2018 17:56 #111092 by Aleks
Replied by Aleks on topic Error stepconfig for lathe
LinuxCNC 2.7.13
Yes, stepgen.2....
We have when configuring lathe:
Axis_X
Stepgen.0...(ok)
Axis_Y
Stepgen.1... (absent)
Axis_Z
Stepgen.2... (error)
24 May 2018 18:08 #111093 by andypugh
You can either use stepgen.1 for Z, or increase the number of stepgens in the loadrt line.
Using stepgen1 for axis.2 is the most efficient way.
25 May 2018 05:33 #111104 by Aleks
I'm doing it. Correcting stepgen.2.... on stepgen.1 ... for axix.2
I'm just reporting a bug in the program StepConfig for lathe.
29 May 2018 13:31 #111259 by andypugh
I have moved the topic out of "Russian" and in to "Steconf" where it might get some more attention from the stepconf developer.
30 May 2018 06:55 #111304 by Aleks
Thank you!
Waiting.
30 May 2018 12:01 #111312 by cmorley
Replied by cmorley on topic Error stepconfig for lathe
confirmed your findings - I will look into as soon as I can.
Chris M
30 May 2018 12:13 #111313 by Aleks
In the version 2.7.12 there is not this problem!
31 May 2018 19:12 #111359 by cmorley
ok pushed a fix for this.
Caused by fixing a bug for: all limits + home option for lathes.
Thanks for the report.
Chris M
The following user(s) said Thank You: andypugh
Time to create page: 0.208 seconds
