Forum Header
Bridgeport cnc with pmdx 126 and 134
- Josh113
28 Jun 2018 20:58 #113030
by Josh113
Bridgeport cnc with pmdx 126 and 134 was created by Josh113
I have a bridgeport cnc with pmdx 126 and 134 with g203v drivers running licuxcnc and need help with configuring it all to work
- tecno
- Thank you received: 127
29 Jun 2018 07:02 #113062
by tecno
Replied by tecno on topic Bridgeport cnc with pmdx 126 and 134
Coming from functional Mach3 configuration?
- Josh113
29 Jun 2018 11:20 #113079
by Josh113
Replied by Josh113 on topic Bridgeport cnc with pmdx 126 and 134
No it was set up for linuxcnc when i got it so all the wiring and everythings done on it and everything worked before but some how the ini and hal file got over written and when i try to run the stepconf wizard i m not sure what to put in to get the steppers to work again i talked to some one at pmdx and they gave me the pin out for the serial port but im not sure on what to set the motors at i tryed a lot of different things that people posted and can get the steppers to move at all im not very familiar with linux at all and this is my frist time messing with a cnc
29 Jun 2018 12:36 #113089
Replied by andypugh on topic Bridgeport cnc with pmdx 126 and 134
Have you looked to see if there are backup copies of the HAL and INI files?
- Josh113
29 Jun 2018 13:23 #113093
by Josh113
Yes and none of them work they come up with a hole list of errors so im guessing there backups never worked
- tecno
29 Jun 2018 13:27 #113094
by tecno
Put the HAL and INI files here so maybe you can get help to sort things out.
Time to create page: 0.504 seconds
