Forum Header
simulation mode
4 years 7 months ago - 4 years 7 months ago #238924 by ajsinfotech
Replied by ajsinfotech on topic simulation mode
Hi dgarrett, thanks for getting involved!
> from Xlib.protocol import event
> ModuleNotFoundError: No module named 'Xlib'
Yes dear, you are right but I underestimate this error because AFAIR it did not appear when I was testing for Axis (and Gmoccapy I think). So, I understand that the only common errors among all the GUIs I tested (QtDragon, Gmoccapy and Axis) were:
> Can not find -sec TRAJ -var TPMOD -num 1
> Can not find -sec EMCMOT -var HOMEMOD -num 1
On the other hand, I trust in you:
The above (irrelevant) messages have been silenced:
Ref:  github.com/LinuxCNC/linuxcnc/commit/e54a8abb3e
But all this comments AFAIU, don't match to me. In Axis the python3-xlib problem did not appear, but all the above did.
So now, I'm getting so lost! image missing /media/kunena/emoticons/blink.png
Anyway, I'll do all you suggest:
1 - I'll do a brand new pull from git
2 - I'll install the python3-xlib
Many thanks dgarrett!
Last edit: 4 years 7 months ago by ajsinfotech.
4 years 7 months ago - 4 years 7 months ago #239005 by ajsinfotech
Hi andypugh, dgarrett!
I did all what you suggest but none of it worked, sorry.
I send you my recent testing logs about qtdragon_auto_tool_probe simulation mode.
I ran dmesg --clear too before run linuxcnc, so dmseg output keeps clean before and after.
I'm absolutely stuck, so any tip are welcome!
Thanks in advance!
File Name: terminal_log.txt
File Size:3.25 KB
File Name: linuxcnc_debug.txt
File Size:61 B
File Name: linuxcnc_print.txt
File Size:870 B
4 years 6 months ago #239036 by andypugh
Replied by andypugh on topic simulation mode
As you spotted, the problem now seems to be a segmentation fault. Which seems unexpected.
Do you get a segfault with the Axis interface too?
4 years 6 months ago #239039 by phillc54
Replied by phillc54 on topic simulation mode
The segfault is possibly caused by python3-espeak during shut down, it is probably not the cause of your issue.
AFAIK there has been no success in getting the QTvcp based GUIs working on a Pi with python3 due to the way the python3-opengl module is built. It is posible this may have been fixed recently but not that I am aware of.
4 years 6 months ago - 4 years 6 months ago #239041 by ajsinfotech
yes
Last edit: 4 years 6 months ago by ajsinfotech.
4 years 6 months ago #239042 by ajsinfotech
Hi phillc54, thanks for getting involved!
Do you mean if I point python interpreter to version 2 it could work ok?
