× Forum Header
spindle speed configuration, odd PWM range
02 Jan 2019 19:20 #123351 by tonydiethelm
spindle speed configuration, odd PWM range was created by tonydiethelm
Hi all,
My spindle control was bought from China and came with an annoying lack of documentation. :D heh.
Speed control is done via a potentiometer. With my trusty multimeter, I measured the control voltage swinging from 0-2.5V. Ok.
So I set out to configure my spindle speed in LinuxCNC. It shouldn't be hard, it's just the worlds sparsest Look Up Table.
Oh, my breakout board does 0-10V output.
Trying for a direct route, I set...
speed1 0 - PWM1 0
speed2 12,000 - PWM2 0.25
A quarter of 10V is 2.5V, that should make a rough speed control from 0V/0RPM to 2.5V/12000RPM. Close enough for me! It doesn't work.... It just outputs 0V for everything. :/
So, I go for an indirect route....
speed1 0 - PWM1 0
speed2 48,000 - PWM2 1
That should make a rough speed control from 0V/0RPM to 2.5V/12000RPM, and I just.... won't go above 12,000RPM? And that totally works, so it's not a problem with the board or its Vout capabilities. It works fine. But it's weird.
So... it's working, but I don't know why it didn't work the first way and I'd love an explanation. But I can live without one.
And yeah, I could have just built a little voltage divider. Eh. Effort. I'm lazy, that's why I built a CNC machine to do my carpentry for me. :D
Is there anything here that I'm not seeing? Is there a danger of higher voltages getting applied to my speed controller?
Thanks all!
:D
Tony
06 Jan 2019 13:18 #123599 by pl7i92
Replied by pl7i92 on topic spindle speed configuration, odd PWM range
can you show a image of the control Board
it might be a regular 0-10V
But you can also get a Regular PWM2Analog device or build your own with a Regulator pot to go down to 2,5V
06 Jan 2019 20:57 #123639 by andypugh
Replied by andypugh on topic spindle speed configuration, odd PWM range
What appears in the HAL for each way of doing it? (That is what really matters)
Time to create page: 0.191 seconds
