Forum Header
Homing Z wants to home X first.
- pl7i92
- Thank you received: 358
05 May 2019 13:56 #132837
by pl7i92
Replied by pl7i92 on topic Homing Z wants to home X first.
Homesequenz -1 is not auto home
Please why Z no Home switch and the others do have
you can put all home reference switches to one pin
and the Z is the first you need to home as it gets the tool FREE
- allistar
05 May 2019 21:07 #132874
by allistar
Replied by allistar on topic Homing Z wants to home X first.
Thanks for the reply.
My machine has no Z limit or home switch because I don't think it needs one and it'll be time consuming to install. The solution I have with the homing sequence of Z set to 0 works well for me. My process after turning the machine on is to always rehome. I used to do Z last by hand but now I'll do it first.
- pl7i92
12 May 2019 16:42 #133576
by pl7i92
ok as you say
did you set
[axis_2]#
HOME_SEQUENCE = -1
axis_0
HOME_SEQUENCE = 0
axis_1
HOME_SEQUENCE = 1
then it shoudt work as you say
did you set
[axis_2]#
HOME_SEQUENCE = -1
axis_0
HOME_SEQUENCE = 0
axis_1
HOME_SEQUENCE = 1
Time to create page: 0.136 seconds
