Forum Header
EMC drive directions are wrong
- beanrider
09 Aug 2010 10:57 #3650
by beanrider
EMC drive directions are wrong was created by beanrider
Hy,
i owned a Haase Cut2000 CNC. I tried to migrate the old DOS-CNC "Step4" programm to EMC2, made the config-Files with the StepConf-Wizard.
Every thing is doing well, incept all driving-directions of the X/Y/Z-directions are going completely in the invers direction.
In the AXIS-Tool the direction is right, as it should be, so i only had to customize the driving-direction and everything is fine.
After reading in this and other forums some guys changed the Par-Port direction with the "-invers" parameter, i tried this to, but nothing helps.
So where can i change the direction of the driving-ways and what parameters did i have to change.
Any help is welcome.
- Thank you received: 4994
09 Aug 2010 12:05 #3653
Replied by andypugh on topic Re:EMC drive directions are wrong
beanrider wrote:
The simplest way is probably to edit the .ini file and convert the SCALE functions to negative (or positive if they are already negative).
Inverting the direction pin into the stepper drives should also work (in the HAL file).
Don't do both, you will end up back where you started.
So where can i change the direction of the driving-ways and what parameters did i have to change:
- beanrider
10 Aug 2010 07:25 #3666
by beanrider
Replied by beanrider on topic Re:EMC drive directions are wrong
Hy,
i changed the scale-parameter on all axes and it work's.
So great thanks for this tip. Great support.
- Thank you received: 2162
11 Aug 2010 04:47 - 12 Aug 2010 02:09 #3683
Replied by cmorley on topic Re:EMC drive directions are wrong
not sure how you did it but:
IN stepconf:
if you negate one of the following (choose only one):
motor steps per revolution
driver micro stepping
leadscrew pitch
or pulley teeth
then the scale will be negative and the drives shouldl be reversed.
without hand modifying the INI file
IN stepconf:
leadscrew pitch
or pulley teeth
Last edit: 12 Aug 2010 02:09 by cmorley.
- beanrider
11 Aug 2010 18:41 #3709
by beanrider
Where and how could i change this, with the wizard?
What i did, is to change the scale entry om the ini-file with a "-", like SCALE="1000" (before) to SCALE="-1000".
- BigJohnT
- Thank you received: 1176
11 Aug 2010 22:36 #3713
by BigJohnT
Replied by BigJohnT on topic Re:EMC drive directions are wrong
For steppers if they go the wrong direction invert the direction pin for that axis on the Parallel Port Setup page.
12 Aug 2010 02:10 #3716
I forgot to mention that i was talking about changes in stepconf. see above
Time to create page: 0.065 seconds
