Forum Header
Jog Wheel in StepConf
- Mike_Eitel
- Thank you received: 184
19 Aug 2010 11:31 #3824
by Mike_Eitel
Jog Wheel in StepConf was created by Mike_Eitel
Hi
I'm using EMC 2.2.4.3 / 3 Axis, all end-switches connected on one pin, external emergency stop, probe..
I wan't to connect a physical Jog Wheel with 2 signals.
I can supply via PC. Signals 5V A/B will probably work fine with parport.
I saw that new SteConf got a lot of more signals but no jog wheel.
When I saw Spindel A /B signals I was wondering if I could easyly generate according for jog wheel
or if there is a way to "missuse" the spindle ones.
THX Mike
P.S.
I looked into EMC doc before, but the example I found was only for MESA..... nothing for parport.
THX Mike
P.S.
- BigJohnT
- Thank you received: 1176
19 Aug 2010 22:42 #3825
by BigJohnT
Replied by BigJohnT on topic Re:Jog Wheel in StepConf
Hi Mike,
Sometimes you just gotta know where to look in the docs.
www.linuxcnc.org/docview/html//examples_mpg.html
- Mike_Eitel
20 Aug 2010 07:55 #3828
by Mike_Eitel
Replied by Mike_Eitel on topic Re:Jog Wheel in StepConf
THX John
Realy ,nicely hidden ;-()
1. I was searching with expresions like "jog Wheel" never came to the idea that "Jog Pendant" is also used.
Ok, I'm not native english.
2. Do you think an ENHANCEMENT of StepConf is easy?
Mike
Mike
- BigJohnT
20 Aug 2010 11:30 #3831
by BigJohnT
2 Easy for some, hard for others, impossible for some
I would say that it is simpler to just add things like the MPG to your custom.hal file than try and get the author of stepconf to add something like MPG to it.
- Mike_Eitel
21 Aug 2010 11:29 #3835
by Mike_Eitel
THX
I looked ofer the code example....
It's not exactly what I want
My idea is to use only 2 HW signals for A / B the rest should be "maneuvered" on Axis screen as usual.
Mike
Mike
Time to create page: 0.063 seconds
