Forum Header
Emc2 On Virtual PC
- saviothecnic
09 Sep 2010 07:47 - 09 Sep 2010 07:48 #4068
by saviothecnic
Emc2 On Virtual PC was created by saviothecnic
Hi I m trying EMC2 on VirtualBox
But I can not go and do more than 800x600 there is a way to force it to 1024x768 with 800x600 not see otherwise good screen stepconfig
Salve sto provando Emc2 su virtualbox
Ma non riesco a farlo andare a piu di 800x600 vi e un modo per forzarlo a 1024x768 altrimenti con 800x600 non vedo bene la schermata di stepconfig
Grazie
Grazie
Last edit: 09 Sep 2010 07:48 by saviothecnic.
- BigJohnT
- Thank you received: 1176
10 Sep 2010 11:44 #4091
by BigJohnT
Replied by BigJohnT on topic Re:Emc2 On Virtual PC
If you used VirtualBox OSE then you need to install vboxadditions to get a much better interface including better resolution.
- saviothecnic
10 Sep 2010 12:29 #4095
by saviothecnic
Replied by saviothecnic on topic Re:Emc2 On Virtual PC
I installed this version
download.virtualbox.org/virtualbox/3.2.8...-3.2.8-64453-Win.exe
On Windows, where I find the Add-On?
Ho installato questa versione
Sotto Windows dove trovo gli Add-On ?
Grazie
Grazie
- BigJohnT
10 Sep 2010 16:07 #4102
by BigJohnT
I've not installed it on windows, so a google search might be in order.
- dab77
11 Sep 2010 09:28 #4116
by dab77
Replied by dab77 on topic Re:Emc2 On Virtual PC
ciao, to install guest additions, just click the right line in the menu, or press 'host key' + D. it will mount an ISO file as a CD rom.
Time to create page: 0.063 seconds
