× Forum Header
10.04.1 w/ EMC2 - Machine axis config Errno 32
09 Sep 2010 23:34 #4080 by rggrieger
Newly installed 10.04.1 w/ EMC2 on an Asus AMD 64 computer. Used Configuration wizard - Stepper Mill Machine Configuration for x, y, and z axis and they all produced the same error when I ran the test and clicked on any option/setting, e.g.-,
"Stepconf encountered an error. The following information may be useful in troubleshooting:
File "/usr/bin/stepconf", line 1911, in on_jogplus_pressed
self.update_axis_params()
File "/usr/bin/stepconf", line 1900, in update_axis_params
halrun.flush()
IOError: [Errno 32] Broken pipe"
Any suggestions/recommendations on how to fix this problem?
Thks,
Bob
10 Sep 2010 00:06 #4081 by cmorley
This usually means HAL was already running or there was an error with HAL.
Try running from a terminal. open a terminal and type stepconf.
There will probably be more info in the terminal when the error appears.
Let us know what it says.
13 Sep 2010 19:53 #4178 by rggrieger
Running stepconfig by itself corrected the error.
Thanks,
Bob
09 Oct 2011 16:51 #13790 by kmonce
Hello,
Any additional information regarding this error?
File "/usr/bin/stepconf", line 1914, in update_axis_params
halrun.flush()
I've ran through the step configuration wizard and have it set up according to the instructions. Any ideas how to correct this error?
Let me know if you need additional information.
thanks-KM
09 Oct 2011 23:32 #13793 by cmorley
run stepconf in a terminal.
the terminal will probably give more information.
post the error message.
Also what version of EMC are you using.
Time to create page: 0.059 seconds
