× Forum Header
Stepconf fails to setup home and/or limit switches
  • davedrumm41@gmail.com
  • New Member
  • New Member
26 Apr 2021 18:29 #207145 by davedrumm41@gmail.com
Stepconf fails to setup home and/or limit switches was created by davedrumm41@gmail.com
Trying for three days to setup LinuxCNC on 3 Axis router that works correctly in Mach3.
Kernel version: Linux LinuxCNC 4.9.0-13-rt-amd64 #1 SMP PREEMPT RT Debian 4.9.228-1 (2020-07-05) x86_64 x86_64 x86_64 GNU/Linux with LinuxCNC Version 2.8.1-96-g86b4f1 and LINUXCNC - 2.8.1-100-g808409424 both fail to work with limit and home switches.
No amount of redos of the Stepconf wizard get home switches or limit switches to work correctly. Best I've seen is the Z home switch actually work reliably. The X & Y limit switches occasionally work if configured as both-x or both-y, but if they are configured as home switches they NEVER work. Remember this machine
File Name: Router.hal
File Size:3 KB
File Name: Router.ini
File Size:3 KB
File Size:3 KB
File Size:3 KB
with the same parallel port BOB works with Mach3... I have gotten the same results on 2 intel and 2 AMD machines all using the same hard drive. Anyone have any idea what is wrong?
26 Apr 2021 18:37 #207147 by Clive S
What is not working
This seems very low MAX_VELOCITY = 0.00913461538462 about 0.5" min.
Do the motors move the machine
  • New Member
  • New Member
26 Apr 2021 19:44 #207162 by davedrumm41@gmail.com
Replied by davedrumm41@gmail.com on topic Stepconf fails to setup home and/or limit switches
The Max Velocity is likely low as I wasn't paying attention to it, just trying to get the machine to home properly.
* * * I have solved to issue by going back to see why Mach3 worked * * *
In Mach3 I had setup the home and limit switches with their auto config routine and my BOB documentation does NOT match the pin numbers of my card. When I put the proper pin numbers in LinuxCNC I'm sure it will work as well.
I am a new user so now I have to figure out how to close this topic!!!
27 Apr 2021 17:52 #207248 by Todd Zuercher
Replied by Todd Zuercher on topic Stepconf fails to setup home and/or limit switches
Did you try importing your working Mach3 XML configuration file into Stepconfig?
Time to create page: 0.204 seconds
