Forum Header
Z home configuration problems
- aterhune1984
19 Sep 2010 15:14 #4251
by aterhune1984
Z home configuration problems was created by aterhune1984
Hello, Just got my home switches set up however I am having some problems on the Z axis.
What I want to happen is the top to be 0, the bottom to be -2~. When the home button is pressed I want the axis to move up until it hits the home switch(which is located on top of the axis) then set the axis to 0 and I will be able to move down to -2~. everything I have tried so far has not worked, can someone give me any suggestions on what configuration I need to put in to get this accomplished. Thanks!
- BigJohnT
- Thank you received: 1176
19 Sep 2010 21:49 - 19 Sep 2010 21:58 #4252
by BigJohnT
Replied by BigJohnT on topic Re:Z home configuration problems
So, what have you tried and what was the result?
Do all the other axis home correctly?
Did you use the Stepconf Wizard to generate you config?
If using the Stepconf Wizard did you read the manual on axis configuration?
www.linuxcnc.org/docview/html//config_st...b:Axis-Configuration
Last edit: 19 Sep 2010 21:58 by BigJohnT.
- aterhune1984
20 Sep 2010 05:16 #4254
by aterhune1984
Replied by aterhune1984 on topic Re:Z home configuration problems
Sorry, figured it out a bit after I posted. If you change the speed to a negative number (-2) it will move in the opposite direction. Thanks though
Time to create page: 0.072 seconds
