Forum Header
Newbie trying to connect to 7i96S for months without success.
4 years 3 weeks ago #253968 by santy
Hello.
i have been trying to connect to 7i96s board via ethernet, but can't seem to configure ethernet properly anytime.
already tried what some guides tell me to do with 10.10.10.10 and also with 192.168(....), but no connection established. anytime i try to open my config it gives me this error:
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl: Print file information: RUN_IN_PLACE=no LINUXCNC_DIR= LINUXCNC_BIN_DIR=/usr/bin LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc LINUXCNC_SCRIPT_DIR= LINUXCNC_RTLIB_DIR=/usr/lib/linuxcnc/modules LINUXCNC_CONFIG_DIR= LINUXCNC_LANG_DIR=/usr/lib/tcltk/linuxcnc/msgs INIVAR=inivar HALCMD=halcmd LINUXCNC_EMCSH=/usr/bin/wish8.6 LINUXCNC - 2.8.4-1-gb7824717b Machine configuration directory is '/home/santiago/linuxcnc/configs/my_LinuxCNC_machine' Machine configuration file is 'my_LinuxCNC_machine.ini' INIFILE=/home/santiago/linuxcnc/configs/my_LinuxCNC_machine/my_LinuxCNC_machine.ini VERSION=1.1 PARAMETER_FILE=linuxcnc.var TASK=milltask HALUI=halui DISPLAY=gmoccapy COORDINATES=XYZ KINEMATICS=trivkins coordinates=XYZ Starting LinuxCNC... Starting LinuxCNC server program: linuxcncsvr Loading Real Time OS, RTAPI, and HAL_LIB modules Starting LinuxCNC IO program: io Starting HAL User Interface program: halui Found file(REL): ./my_LinuxCNC_machine.hal Shutting down and cleaning up LinuxCNC... Running HAL shutdown script hm2: loading Mesa HostMot2 driver version 0.15 hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2 hm2_eth: ERROR: Could not retrieve hardware address (MAC) of 10.10.10.10: Resource temporarily unavailable hm2: unloading Removing HAL_LIB, RTAPI, and Real Time OS modules Removing NML shared memory segments Debug file information: cannot gain I/O privileges - forgot 'sudo make setuid' or using secure boot? -parallel port access is not allow Note: Using POSIX realtime hm2_eth: rtapi_app_main: Resource temporarily unavailable (-11) ./my_LinuxCNC_machine.hal:11: waitpid failed /usr/bin/rtapi_app hm2_eth ./my_LinuxCNC_machine.hal:11: /usr/bin/rtapi_app exited without becoming ready ./my_LinuxCNC_machine.hal:11: insmod for hm2_eth failed, returned -1 2296 Stopping realtime threads Unloading hal components cannot gain I/O privileges - forgot 'sudo make setuid' or using secure boot? -parallel port access is not allow Note: Using POSIX realtime ----------------------------------------------------------------------- Info report created by linuxcnc_info: The file: /tmp/linuxcnc_info.txt can be posted to a forum or a web site like: http://pastebin.com in order to provide information about the linuxcnc system and configuration. Date: Tue 11 Oct 2022 11:10:48 AM CDT UTC Date: Tue 11 Oct 2022 04:10:48 PM UTC this program: /usr/bin/linuxcnc_info uptime: 11:10:48 up 17:20, 1 user, load average: 0.71, 0.65, 0.42 lsb_release -sa: Debian Debian GNU/Linux 10 (buster) 10 buster which linuxcnc: /usr/bin/linuxcnc pwd: /home/santiago/linuxcnc/configs/my_LinuxCNC_machine USER: santiago LOGNAME: santiago HOME: /home/santiago EDITOR: VISUAL: LANGUAGE: TERM: dumb COLORTERM: DISPLAY: :0.0 DESKTOP: lightdm-xsession display size: 1366x768 pixels (361x203 millimeters) PATH: /usr/bin:/home/santiago/linuxcnc/configs/my_LinuxCNC_machine/bin:/usr/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games uname items: nodename -n: debian kernel-name -s: Linux kernel-vers -v: #1 SMP PREEMPT RT Debian 4.19.249-2 (2022-06-30) machine -m: x86_64 processor -p: unknown platform -i: unknown oper system -o: GNU/Linux /proc items: cmdline: BOOT_IMAGE=/boot/vmlinuz-4.19.0-21-rt-amd64 root=UUID=1073611f-6daa-44db-84b6-17f98c586813 ro quiet model name: Intel(R) Core(TM) i7-3630QM CPU @ 2.40GHz cores: 4 cpu MHz: 1199.739 parport: serial: Versions: gcc: gcc (Debian 8.3.0-6) 8.3.0 python: Python 2.7.16 git: not_in_PATH git commit: NA tcl: 8.6 tk: 8.6 glade: not_in_PATH glade-gtk2: not_in_PATH linuxcnc_var all: LINUXCNCVERSION: 2.8.4-1-gb7824717b LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples REALTIME: /etc/init.d/realtime RTS: uspace HALLIB_DIR: /usr/share/linuxcnc/hallib dpkg -l '*linuxcnc*': Desired=Unknown/Install/Remove/Purge/Hold | Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad) ||/ Name Version Architecture Description +++-===================-====================-============-===================================================================== un linuxcnc <none> <none> (no description available) un linuxcnc-dev <none> <none> (no description available) un linuxcnc-doc <none> <none> (no description available) ii linuxcnc-doc-en 1:2.8.4.1.gb7824717b all motion controller for CNC machines and robots (English documentation) ii linuxcnc-doc-es 1:2.8.4.1.gb7824717b all controlador de movimiento para máquinas CNC y robots (Español). ii linuxcnc-doc-fr 1:2.8.4.1.gb7824717b all motion controller for CNC machines and robots (French documentation) un linuxcnc-sim <none> <none> (no description available) un linuxcnc-sim-dev <none> <none> (no description available) ii linuxcnc-uspace 1:2.8.4.1.gb7824717b amd64 motion controller for CNC machines and robots ii linuxcnc-uspace-dev 1:2.8.4.1.gb7824717b amd64 PC based motion controller for real-time Linux
4 years 3 weeks ago #253970 by tommylight
Why are you trying to use a parallel port config with Mesa 7i96S?
And why did you use "sudo" where you were not supposed to?
Start with a new install, then follow this:
forum.linuxcnc.org/27-driver-boards/3559...ethernet-mesa-boards
4 years 3 weeks ago #253977 by santy
Yes but with a new install ethernet is not yet configured with a static ip, so im having quite some trouble.
here are some pictures of some commands . im using eeprom connection so i thought a 10.10.10.10 ip would work.
4 years 3 weeks ago #253986 by PCW
It appears you have not set a static IP address
using the network manager GUI
tommylights post gives the instructions for this
4 years 1 week ago #255064 by smc.collins
4 years 4 days ago #255336 by rodw
www.itzgeek.com/how-tos/linux/debian/how...-9-ubuntu-16-04.html
newer versions of debian FORCE IPV6
Thats not right. I have had no trouble setting a static ip address 10.10.10.1 on kernels up to  V 6.1 the bleeding edge version thats not even in Debian 12. The documentation covers it nicely. (if you know where to look)
linuxcnc.org/docs/devel/html/man/man9/hm...FACE%20CONFIGURATION
Time to create page: 0.234 seconds
