Forum Header
New interface for EMC 2
- namnp2007
21 Oct 2010 13:59 - 21 Oct 2010 14:14 #4773
by namnp2007
New interface for EMC 2 was created by namnp2007
Dear all.
I'd like to used EMC2 for a wirecut machine. I modifyed my-mill.hal and my-mill.ini as attached files, but EMC2 says I have some mistake. Pls. help me to fix this problem. I'm a newbie of EMC2 and Linux, and sorry for my English.
Thanks for your time.
Last edit: 21 Oct 2010 14:14 by BigJohnT. Reason: remove duplicate file links
- BigJohnT
- Thank you received: 1176
21 Oct 2010 14:24 #4776
by BigJohnT
Replied by BigJohnT on topic Re:New interface for EMC 2
What is the error you have?
- namnp2007
22 Oct 2010 03:11 - 22 Oct 2010 03:12 #4783
by namnp2007
Replied by namnp2007 on topic Re:New interface for EMC 2
Dear BigJohn
I don't know why I can't attached more files. Pls. see the attached file. It's says the 6th axis it's not config correctly, but I don't know how to use HAL to config it( I write all parameter myseft directly to the file).
Could you guide me to use HAL.
Thanks.
Thanks.
Last edit: 22 Oct 2010 03:12 by namnp2007.
- step4linux
- Thank you received: 5
22 Oct 2010 06:04 #4785
by step4linux
Replied by step4linux on topic Re:New interface for EMC 2
you use stepgen.7 in your hal file
This requires 8 stepgens (0...7).
modify line 9 of hal:
rgds, Gerd
loadrt stepgen step_type=0,0,0,0,0,0,0,0
rgds, Gerd
- BigJohnT
22 Oct 2010 11:51 #4789
by BigJohnT
You can only attach one file per message. If you try and attach more you just get duplicates. No big deal.
- namnp2007
23 Oct 2010 01:37 - 23 Oct 2010 02:18 #4806
by namnp2007
Thanks you all. I solved the problem.
Last edit: 23 Oct 2010 02:18 by namnp2007.
Time to create page: 0.069 seconds
