Forum Header
'Test this axis'
2 years 6 months ago #298698 by JohnBr00ker
'Test this axis' was created by JohnBr00ker
Having just cleaned a huge insect nest out of my old SuperCam controller box, I've got as far as trying to establish the correct address for the parport.Checking in the Dell bios, it lists 378h, which I entered.Getting as far as 'Test this axis' for the X axis, I got an error pop up as attached (Had to photo the screen).While I still have question marks over various other entries, I'd be grateful if anyone could interpret this for me.Possible extra info - when I turn on the power to the controller, I would have expected there to be a reaction from the steppers, just being activated. Is this so ? Nothing, in my case.Regards John
2 years 6 months ago #298718 by andypugh
Replied by andypugh on topic 'Test this axis'
The very old advice here might help. Or it might not.
forum.linuxcnc.org/16-stepconf-wizard/27...pe-error-in-stepconf
2 years 6 months ago #298731 by JohnBr00ker
Replied by JohnBr00ker on topic 'Test this axis'
Thanks Andy - any port in a storm !
2 years 6 months ago - 2 years 6 months ago #299333 by JohnBr00ker
I've just had a brain wave - checked the parport mode in the bios, and discovered the default setting for this pc is PS/2.
Now faced with decision - EPP or ECP ?
EPP gives 2 addresses - 378h or 278h ?
ECP gives 3 addresses - 378h, 278h and 3BCh.
In addition, ECP then offers a DMA channel setting - OFF, DMA1 or DMA3
Feel I've opened a can of worms, but may be on the right track !
EDIT I've tried EPP with both addresses, but in both case I get the 'Error - broken pipe' pop up.
Last edit: 2 years 6 months ago by JohnBr00ker. Reason: update
2 years 6 months ago #299336 by tommylight
Replied by tommylight on topic 'Test this axis'
Broken pipe is a python error, i think, so has nothing to do with parallel port.
Set it to EPP and 0x378.
Got through stepconfig, enter values as correctly as you can, save the config, start said config and test the machine.
Use the Calibration from the Machine menu to tweak and tune the scale till you get precise distance traveled.
2 years 6 months ago #299337 by JohnBr00ker
Many thanks for the quick reply.
1st job after we've eaten !
Time to create page: 0.388 seconds
