- Configuring LinuxCNC
- Configuration Tools
- StepConf Wizard
- Stepconfig wont set up tandem y axis limit and home?
Forum Header
- redeye_joe
07 Jul 2024 20:32 #304621
by redeye_joe
Stepconfig wont set up tandem y axis limit and home? was created by redeye_joe
I am trying to set up a xyyz and when I do the stepconfig it wont set up a input limit switch y2 on my joint 2, even though I set up the input as tamdem y limit and home, it sets the hal as "a" limit and home. and it also it doesnt set up my z limit and home, in the hal it shows up as u limit and home? Am I missing something? or does this need to be modified in the hal with an editor?
- Thank you received: 7504
15 Jul 2024 00:59 #305194
Replied by tommylight on topic Stepconfig wont set up tandem y axis limit and home?
At the very start did you choose XYZ or XYZA machine?
Choose XYZ.
You can also manualy edit the hal and ini files, but requires a bit of attention, although LinuxCNC is very good at pointing what is wrong.
Choose XYZ.
- Thank you received: 4154
15 Jul 2024 03:26 #305211
Replied by rodw on topic Stepconfig wont set up tandem y axis limit and home?
Sounds like you may be using 2.7 or lower.
Please use the 2.9.3 ISO on the downloads page.
- StepConf Wizard
Time to create page: 0.514 seconds
