Forum Header
External Run command
- eddycnc
18 Nov 2010 07:11 #5392
by eddycnc
External Run command was created by eddycnc
Hi to all,
My question is very simply.
Is possible to map the run command (in the axis interface is the symbol Play or "R") on an parallel input pin?
Thanks in advance
Thanks in advance
- Thank you received: 5018
18 Nov 2010 12:49 #5400
Replied by andypugh on topic Re:External Run command
Yes, though it seems to no longer be as easy as it used to be.
You need to load halui:
linuxcnc.org/docs/html/gui_halui.html
That gives you a HAL pin called halui.program.run
I think you might also need to set halui.mode.manual to false and halui.mode.auto to true.
- BigJohnT
- Thank you received: 1177
18 Nov 2010 12:51 #5401
by BigJohnT
Replied by BigJohnT on topic Re:External Run command
Time to create page: 0.058 seconds
