Forum Header
Help with Mesa 7I97T card CCW and CW
- akim14
- Thank you received: 3
06 Oct 2024 18:50 #311456
by akim14
Help with Mesa 7I97T card CCW and CW was created by akim14
Can the 7I97T output pins be configured to generate CCW and CW signals instead of the standard PWM ±10V? I mistakenly purchased servo drivers that only accept CW and CCW inputs, so I'm seeking a solution
- Thank you received: 5337
06 Oct 2024 19:06 #311457
Replied by PCW on topic Help with Mesa 7I97T card CCW and CW
No, you would need a card with buffered 5V outputs for that.
A 7I96S would be a better choice if you don't need per axis encoders.\
or 7I95T if you do need encoders.
You could add a daughter card to the 7I97T to get step dir outputs
say a mesa 7I85S or a generic parallel port breakout, like the
common "Mach 5 Axis breakout"
The following user(s) said Thank You: PhilipME
Time to create page: 0.179 seconds
