× Forum Header
Mix and match drivers?
19 Nov 2010 20:38 #5446 by jeoslislo
Mix and match drivers? was created by jeoslislo
Can two different drivers/motors types be used in the same setup?
For example, can a servo motor with a gecko 320 driver be used on one axis and a stepper motor with a gecko 302v driver used on another? The StepConf wizard only allows for one type. The default values for the 320 are step time:3500 ns, step space:500 ns while the 302v default values are step time 1000 ns, step space:2000 ns. Can a hybrid "other" drive be specified with step time:3500 ns, step space:2000 ns to come up with a suitable compromise?
Thanks, Jim
19 Nov 2010 23:40 - 19 Nov 2010 23:40 #5454 by BigJohnT
Replied by BigJohnT on topic Re:Mix and match drivers?
I think you could work that out if you just set the step and step space to the slowest drive number of the two different drives. So if the timing is slow enough for the slowest drive the faster drive is sure to keep up without problems.
Last edit: 19 Nov 2010 23:40 by BigJohnT.
20 Nov 2010 13:31 #5462 by jeoslislo
Replied by jeoslislo on topic Re:Mix and match drivers?
That sounds like a plan. I'll give it a try and report the results.
Time to create page: 0.050 seconds
