- Configuring LinuxCNC
- Configuration Tools
- StepConf Wizard
- Homing an axis moves away from home switch!
- Thank you received: 7504
If yes, the home_latch_velocity is set reversed, so add or remove - in front of the value.
- Clive S
- Thank you received: 486
- Clive S
You are not helping yourself with comments like this.
As said already. Post the ini and hal files
1. because you told it so.I don't understand why it does not work with just the stepconf config.
Why is LinuxCNC so stupid?
Why does it move away from zero and toward 20 while homing????!!!
2. it is not.
3. because you told it so.
Try changing "home latch direction" in StepConf for each axis that needs it.
- Thank you received: 426
But if you can’t do that what’s more annoying, copying the files or not being happy with your machine ?
If you want to be helped you need to provide the info.
Without the info it’s hard to impossible for those helping and you don’t get the answers you require.
- Clive S
The settings are in the ini and hal files
Just post them
To be able to do that for any of the huge variety of machines that LinuxCNC can control, it would require the software to be SENTIENT!!!LinuxCNC should have some auto config option where you just let it run and it figures out where the home switchs are and everything.
Nothing humanity can create can do that the way you think.
Try AI
Off topic:
AI = absolutely not artificial intelligence, not in the slightest, just the name being misused.
Same with:
Calling a liquid "GAS"
Calling "football" a sport that does not use feet.
Etc, etc.
- Thank you received: 2177
- Clive S
Yes it is, granted you set the soft limits correctly in the wizard or in the ini file.Is it okay to set it as just "Home X"?
- StepConf Wizard
