× Forum Header
Homing an axis moves away from home switch!
  • tommylight's Avatar Topic Author
  • Moderator
  • Moderator
13 Jan 2025 23:06 #318897 by tommylight
Does the machine have separate homing and limit switches?
If yes, the home_latch_velocity is set reversed, so add or remove - in front of the value.
14 Jan 2025 17:10 #318967 by Clive S
Replied by Clive S on topic Homing an axis moves away from home switch!
Can you post the ini and hal files.
21 Jan 2025 17:06 #319577 by Clive S
Why is LinuxCNC so stupid?
You are not helping yourself with comments like this.
As said already. Post the ini and hal files
The following user(s) said Thank You: pommen
  • Moderator
  • Moderator
22 Jan 2025 00:09 #319601 by tommylight
Replied by tommylight on topic Homing an axis moves away from home switch!
I don't understand why it does not work with just the stepconf config.
Why does it move away from zero and toward 20 while homing????!!!
1. because you told it so.
2. it is not.
3. because you told it so.
Try changing "home latch direction" in StepConf for each axis that needs it.
  • Platinum Member
  • Platinum Member
22 Jan 2025 11:08 #319626 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic Homing an axis moves away from home switch!
Boot into Ubuntu, mount the linuxcnc partition and bingo you have access to the files.
But if you can’t do that what’s more annoying, copying the files or not being happy with your machine ?
If you want to be helped you need to provide the info.
Without the info it’s hard to impossible for those helping and you don’t get the answers you require.
22 Jan 2025 15:46 #319642 by Clive S
Why are you still whinging ?
The settings are in the ini and hal files
Just post them
  • Moderator
  • Moderator
22 Jan 2025 16:52 #319645 by tommylight
LinuxCNC should have some auto config option where you just let it run and it figures out where the home switchs are and everything.
To be able to do that for any of the huge variety of machines that LinuxCNC can control, it would require the software to be SENTIENT!!!
Nothing humanity can create can do that the way you think.
Try AI
Off topic:
AI = absolutely not artificial intelligence, not in the slightest, just the name being misused.
Same with:
Calling a liquid "GAS"
Calling "football" a sport that does not use feet.
Etc, etc. :)
22 Jan 2025 18:31 - 22 Jan 2025 18:38 #319654 by Aciera
Replied by Aciera on topic Homing an axis moves away from home switch!
You could sure make all of this SO much easier by simply providing the basic information you have been asked for.
Last edit: 22 Jan 2025 18:38 by Aciera.
The following user(s) said Thank You: Cant do this anymore bye all
22 Jan 2025 19:37 #319663 by Clive S
I give up!
  I
  • Moderator
  • Moderator
22 Jan 2025 20:14 #319669 by tommylight
Is it okay to set it as just "Home X"?
Yes it is, granted you set the soft limits correctly in the wizard or in the ini file.
Time to create page: 0.182 seconds
