- Configuring LinuxCNC
- Configuration Tools
- StepConf Wizard
- Config file with multiple .ini and.hal files
Forum Header
- captain chaos
- Thank you received: 3
15 Feb 2025 16:00 #321666
by captain chaos
Config file with multiple .ini and.hal files was created by captain chaos
On building a new machine, DELL Vostro 220, I have run the Stepper config multiple times as I have made improvements to the machine to achieve better latency and have multiple .ini and .hal files.
I'm now about to edit my the .ini and .hal files to add an extra Y joint.
As it seems to serve no purpose Is it ok to remove those earlier files from the config folder?
Thanks Paul
Thanks Paul
- Thank you received: 7504
15 Feb 2025 16:30 #321671
Replied by tommylight on topic Config file with multiple .ini and.hal files
Each config should have it's own folders, and yes you can delete those, but if you edited the same config do not delete stuff before making a backup or copy the folder somewhere else.
The following user(s) said Thank You: captain chaos
- StepConf Wizard
Time to create page: 0.142 seconds
