Forum Header
Again about HOME_INDEX in step/dir mode
7 months 2 weeks ago #344238 by Taichi
Hello everyone. I haven't been to the forum for a long time.
Need help and complete clarity in using HOME_INDEX = YES and STEP/DIR
When I upgraded old machines that used analog control and encoder feedback, this issue was not there. In the topic Homing index andypugh writes and gives a link to the source file homing.c. I asked chatGPT to analyze this file. And the chat says that indeed to reset the HOME_INDEX search flag you need a signal from encoder.n.index-enable. That is, linuxcnc does not support the function of searching for 0 labels in step/dir mode.
Most of the new hobby machines that I and my friends are currently assembling use servos in step/dir mode and without a closed loop. Since for a hobby, the driver <-> motor with encoder connection is enough. But home_switch gives a small but noticeable error. Therefore, such a request will appear more and more often.
On my 7i92 there are no free 9 pins for 3 x A B Z encoders. And almost all servo drivers have a simple transistor output that duplicates the 0 encoder mark.
Are there any "macros" or "tricks" to get around this problem?
Is it possible to add this functionality to the homing.c source?
Thx for help.
7 months 2 weeks ago #344244 by andrax
If your 7i92 doesn't have a free input for the Z signal, that's too bad. I'd recommend upgrading so you have more inputs. Alternatively, you can set HOME_USE_INDEX = No, and then LinuxCNC will use the home switch for reference. However, this is less accurate.
7 months 2 weeks ago - 7 months 2 weeks ago #344246 by rodw
Do not fight the paradigm to avoid a world of pain.
To say you have open loop is not correct. your encoder output should be fully wired in so you do have a feedback loop. Some machines have a dual feedback loop with the motor encoder configured in velocity mode inner loop and optional linear scales configured in position mode as the outer loop.
There are many closed loop stepper motors with encoders and a few also have an index signal. Usually the dual feedback system connects the motor encoder velocity feedback to the drive and the position feedback to linuxcnc.
I have never had drives with index marks but my uderstanding  is that linuxcnc can search for a home switch, then move to the nearest index pulse before completing homing. Ethercat drives that home internally are different animal altogether
Last edit: 7 months 2 weeks ago by rodw.
7 months 2 weeks ago #344250 by rodw
forgot to mention granite devices have a good article about feedback systems and even mentions Linuxcnc
granitedevices.com/wiki/Dual-loop_feedback_position_control
7 months 2 weeks ago - 7 months 2 weeks ago #344257 by PCW
Mesa Hostmot2 supports homing to index on step/dir systems.
It requires firmware that supports step/dir Index (normally
such firmware has "SDI" in it's name). It also requires one free
input per step/dir channel for the index signal.
This allows homing to index  and spindle synchronized motion  on
step/dir systems without encoder feedback to LinuxCNC.
Last edit: 7 months 2 weeks ago by PCW.
7 months 2 weeks ago #344268 by Taichi
Thanks for the answers. As I understand it, the differences in the answers mean that there is no single solution in the system. Why is such a question even raised? Systems with hybrid or servo drivers already cost almost the same as stepper motors. Of course, if a person does not use Sinumerik, Fagor, Fanuc, he is looking for a way to save money. Therefore, the 7i92 + 2 x ABOB combination is simply an ideal solution for the price of quality. And to make your own hobby machine with perfect homing, and even at a low price, it is impeccable.
It is also clear that this functionality can be implemented programmatically. I will also try to find the firmware you are talking about. Does it mean that in the firmware the encoder index is untied from the counter?
I will try to implement this using the GPT chat, but I do not think that I will succeed with my little knowledge of code programming.
With respect
Time to create page: 0.421 seconds
