Forum Header
Machine Zero (HOME)
- sjcdcheu
12 Jan 2011 15:36 #6649
by sjcdcheu
Machine Zero (HOME) was created by sjcdcheu
I am using the 3-axis stepping motor with HOME switched and EMC2 2.3 installed. It is no problem to let the EMC2 to go home zero by click HOME button on screen. However, it may possible the stepping motor missing some step when G0 X0Y0Z0 and it is not the machine zero. Is it a way I can send the code either G/M/O code or via ParPort to request EMC2 to go HOME.
Thank & My Best Regards
Dason
Dason
- BigJohnT
- Thank you received: 1176
12 Jan 2011 16:14 #6650
by BigJohnT
Replied by BigJohnT on topic Re:Machine Zero (HOME)
Dason,
With a stepper machine you must configure you acceleration and speed so you never miss a step. Once a step has been missed for what ever reason no control can possibly know where home actually is without homing again.
You can use the halui.home-all pin to make your machine home again via the parallel port.
- sjcdcheu
12 Jan 2011 17:00 #6651
by sjcdcheu
Replied by sjcdcheu on topic Re:Machine Zero (HOME)
Thank! John, I am going to try to use the ParPort Pin 8 as input. I am very apprecipate if if you can help me to confirm the below
net program-run <= parport.0.pin-8-in
net program-run => halui.home-all pin
or
net halui.home-all pin => parport.0.pin-8-in
Thank again,
My Best Regards,
Dason.
or
Thank again,
My Best Regards,
Dason.
- Thank you received: 4994
12 Jan 2011 17:10 #6652
Replied by andypugh on topic Re:Machine Zero (HOME)
sjcdcheu wrote:
Is how I would do it.
Will work, (except for the spurious word "pin" but program-run would be an unsual name to choose for the signal.net program-run <= parport.0.pin-8-in
I prefer this format, but you still need to choose a signal name. The arrows are only for human readers, so it doesn't matter, but your arrow points the wrong way.net halui.home-all pin => parport.0.pin-8-in
net ext-home halui.home-all <= parport.0.pin-8-in
- sjcdcheu
12 Jan 2011 17:21 #6653
by sjcdcheu
John, thank for your quick solution.
My Best Regards,
Dason.
My Best Regards,
Dason.
Time to create page: 0.064 seconds
