Forum Header
EMC2 KELING 4030 & c10 bob
- NINJA
31 Jan 2011 02:53 #6884
by NINJA
EMC2 KELING 4030 & c10 bob was created by NINJA
IM NEW TO ALL THIS SO PLEASE EXCUSE THE IGNORANCE
Ive been through the steppermill config wizard and have run test on x,y,z, axis all axis work well, but when i go into emc2 i am unable to get it to work and can not figure out how to move the machine manualy, i know i'm
missing some other setup con figures , what is the tool edit table used for, what is the hall config , so many more , but Ill start with these first , basicaly im asking for step by step config for my 3 axis keling 4030 and a c10
bob set up so that I can get this machine to work , i have used mach 3 but i would like to use the emc2
PLEASE HELP
Thank you
PLEASE HELP
Thank you
- Kirk_Wallace
- Thank you received: 4
31 Jan 2011 03:35 #6885
by Kirk_Wallace
Replied by Kirk_Wallace on topic Re:EMC2 KELING 4030 & c10 bob
I tend to think of the config wizzards as something that can get you going, especially if you have a fairly "standard" machine, but you should expect to need to go in and edit the config files by hand.
You'll need to know this stuff:
www.linuxcnc.org/docview/html/common_Linux_FAQ.html
When you have gone through the above, the configuration files are under your home directory, /home/my_home/emc2/configs/my_machine/... The base file is the .ini file, my_machine.ini. If you study this file (using gedit), you can see that it calls the other files that are needed, usually one or more .hal files, a tool table, one or two files that save session information (so EMC2 can use the same settings between power off) and a few others.
Setting up a pendant is not really beginner's stuff, so you'll need to be patient. Look on this wiki page for pendants, wiki.linuxcnc.org/cgi-bin/emcinfo.pl .
In the mean time you should be able to jog with the arrow keys for X and Y, page up/down controls Z. In AXIS, click on Help, then Quick Reference to see the key assignments.
The tool table holds the tool information for cutter length and radius compensation:
linuxcnc.org/docs/html/gcode_tool_compensation.html
The .hal file contains the software pin and signal connections. You will need to make the signal connections between EMC2 and your pendant there. You might want to practice with more basic features first, such as lighting up an LED from a parallel port pin, or sensing a switch on an input pin, then move up in complexity.
There is a ton of configuring that you can do, which you may not be used to with Mach 3, but there is a lot of power that comes with EMC2 if you want to take advantage of it. Good luck, ask questions.
Kirk Wallace
www.wallacecompany.com/machine_shop/
www.wallacecompany.com/E45/index.html
California, USA
Kirk Wallace
California, USA
- Rick G
- Thank you received: 155
31 Jan 2011 11:20 #6894
by Rick G
Replied by Rick G on topic Re:EMC2 KELING 4030 & c10 bob
Take a look here..
www.linuxcnc.org/docs/EMC2_User_Manual.pdf
Try section 4.2 getting started
Rick G
Rick G
- Thank you received: 4994
31 Jan 2011 13:03 #6896
Replied by andypugh on topic Re:EMC2 KELING 4030 & c10 bob
NINJA wrote:
You need to take EMC2 out of E-stop and turn it on (press F1 then F2, or click the top left button in Axis, and then the one next to it.
If you have already done this, then it might be an issue with the amp-enable lines,
