× Forum Header
I can not configure limits and home
09 Feb 2011 08:20 #7091 by cmorley
Replied by cmorley on topic Re:I can not configure limits and home
ok then invert the limit pin (as above ) and negate (make it negative) the search velocity.
Negating the search velocity should make it search in the opposite direction.
  • aguseguedre
  • aguseguedre's Avatar Topic Author
  • Visitor
  • Visitor
09 Feb 2011 08:22 #7092 by aguseguedre
Replied by aguseguedre on topic Re:I can not configure limits and home
The BOB that I have is :
www.esteca55.com.ar/proye-interfazcnc12.html
Regards.
09 Feb 2011 08:24 #7093 by cmorley
Oh and after I looked at your interface card a little closer, I think it is actually the stepper driver.
A break out board (BOB) is actually a board between the parallel port and the step driver.
It 'breaks out ' the connections from the parallel port so you can wire them to a step driver.
Some BOB 's have charge pumps included and are isolated.
Just to be clear :)
  • aguseguedre
  • Visitor
  • Visitor
09 Feb 2011 08:27 #7094 by aguseguedre
Ok I will try this evening because I am not at home.
Thanks.
  • aguseguedre
  • Visitor
  • Visitor
09 Feb 2011 08:34 #7095 by aguseguedre
I cal this a " INTERFACE" and it is like you said is a board between the parallel port and step driver. The switches are connected too in this board. It have too three relays for router,ect.
  • aguseguedre
  • Visitor
  • Visitor
10 Feb 2011 23:26 - 10 Feb 2011 23:27 #7121 by aguseguedre
Hello Cmorley,
I did that you said me and the X and Y axis homing well. With the z axis still appear the error when I jogged. I do not know if that was the the better configuration but I had the home at the top of the travel with the maximum value. I changed the home to the bottom with minimum value. Now when I jog the error messages do not appear.
Thanks for your aid and patience:)
I said you " hasta Luego" see you soon because I have some problems with real time and RTPAI . Is better open a new thread?
Regards
Last edit: 10 Feb 2011 23:27 by aguseguedre.
11 Feb 2011 01:38 #7129 by cmorley
well glad your figuring it out!
yes start a new thread for the realtime trouble
Time to create page: 0.079 seconds
