Forum Header
Got a error msg help
- Noted1
20 Sep 2009 06:27 #843
by Noted1
Got a error msg help was created by Noted1
- robh
- Thank you received: 24
20 Sep 2009 10:21 #844
by robh
Replied by robh on topic Re:Got a error msg help
update to new version this problem has been fixed if u dont want to update untick the make desktop shortcut option
- Noted1
20 Sep 2009 17:28 #846
by Noted1
Replied by Noted1 on topic Re:Got a error msg help
Thanks unchecking the box did fix it but I thought I had the most recent I found the newest version
this is really taking some effort, but when the learning curve flattens, I think it is going to be worth it, this software doubles the rapid speeds on my router
Thanks again
Thanks again
- robh
20 Sep 2009 20:11 #848
by robh
glad it helps, yes lerning can be steep with EMC and hal etc but once u take time effort to learn it all the rewards are big and can will find ur self doing pritty much anything u can think of
good luck
good luck
Time to create page: 0.059 seconds
