- Configuring LinuxCNC
- Configuration Tools
- StepConf Wizard
- Negative home position seems to NOT work ???
Forum Header
- kreature
23 Apr 2011 13:41 #9281
by kreature
Replied by kreature on topic Re:Negative home position seems to NOT work ???
Thanks.
I was at the local hw store just now and scored some 8mm precision threaded rods that should be better for feeds.
M8x1.25 should be better than M5x0.8 seeing how I have plenty position-accuracy vs stiffness in the design and could use the extra speed.
Also I got perfectly straight rods so no more whipping. Especially when I support em in both ends.
I also got some more MDF so I can make a longer Y table. The plan has always been to use a longer Y table if I need to, and it seems I need 300mm range on Y while my design only delivers 170 now.
Due to the flying X/Z I do have better range there than traditional gantry design though.
I can use entire width of table in X, It also allows tool length sensor to be located outside the main table area to be always available regardless of Y position. (Saving repositioning time when changing tools.)
I also have started work on a ultrasonic touchprobe that will allow contact probing without pressure and should as such yeld very accurate probing results even on soft materials.
- BigJohnT
- Thank you received: 1176
23 Apr 2011 15:50 #9282
by BigJohnT
Replied by BigJohnT on topic Re:Negative home position seems to NOT work ???
What is the hysteresis and repeatably of the ultrasonic sensor?
- kreature
24 Apr 2011 15:08 #9298
by kreature
Won't know untill I finish it, but it should be good as near-contact should be easily distinguishable from actual contact.
That's one of the things that will be most fun to find out...
It is a bit more high tech than a springloaded set of contacts though. Luckally that's my job
- BigJohnT
24 Apr 2011 15:19 #9300
by BigJohnT
So your building an ultrasonic sensor? I thought you were using an off the shelf sensor... I can't wait to see that in action.
- kreature
24 Apr 2011 20:22 #9302
by kreature
Yes. It is basically a ultrasonic resonator with a probe-tip on. When it touches something the resonance changes/dies-down.
In theory it should work but will be fun finding out just how hard it is.
- Thank you received: 4994
26 Apr 2011 10:17 #9323
Replied by andypugh on topic Re:Negative home position seems to NOT work ???
Sounds interesting. Though the Renishaw-style contact probes are very light contact, and very accurate (it's quite a clever design)
- BigJohnT
26 Apr 2011 16:41 #9340
by BigJohnT
Andy,
Do you have a link that describes the Renishaw-style contact probe? I've seen homemade probes but wonder what the real one uses.
26 Apr 2011 20:53 - 26 Apr 2011 22:00 #9350
BigJohnT wrote:
www.wikipatents.com/US-Patent-5146691/touch-probe/Page-1
The real one uses pretty much the same thing:Do you have a link that describes the Renishaw-style contact probe? I've seen homemade probes but wonder what the real one uses.
Last edit: 26 Apr 2011 22:00 by BigJohnT.
- StepConf Wizard
Time to create page: 0.076 seconds
