× Forum Header
Fault M3, OK M3 S20000?
13 Oct 2009 18:00 #971 by radioelf
Fault M3, OK M3 S20000? was created by radioelf
Hello, I configured EMC2 with wizard and I order everything correctly except M3 Gcode, M3 S20000 is OK but not with M3 as I set the pin "spindle ON". Thanks
Sorry, automatic translation :unsure:
Hola, configuré EMC2 con el Wizard, y me funciona todo correctamente, ecepto el Gcode M3, si que me funciona si utilizao M3 S20000 por ejemplo, tengo configurado el pin como "spindle ON" Gracias
Time to create page: 0.130 seconds
