Forum Header
Stepconf settings?
- Boosted3s
12 May 2011 23:46 #9776
by Boosted3s
Stepconf settings? was created by Boosted3s
I have just recently started to build a cnc seig X2 mill, I am using EMC2 but am having a few issues with the axis directions and such. I was wondering if anyone might have some setting for this setup which I could compare to mine. Here is my setup. Seig X2 mill, Geckodrive g540, keling 387oz motors, 48v power supply, CNC Fusion motor mount and ball screw kit on X,y and z axis. I have home switches mounted on the top of themill for the z axis, the y axis switch is to the rear and the x axis switch is on the front left side of the table, so it moves all the way to the right to activate it. Any input you may have will be greatly appreciated. Thanks
- BigJohnT
- Thank you received: 1176
12 May 2011 23:56 #9777
by BigJohnT
Replied by BigJohnT on topic Re:Stepconf settings?
Are you using the Stepconf to generate your configuration?
If so just invert the direction pin to get the axis to move the other way.
- czerech
13 May 2011 08:01 #9779
by czerech
Replied by czerech on topic Re:Stepconf settings?
You can easyly change it in HAL file.
just add "-not" to Your direction pin.
regards,
Piotr
regards,
Piotr
Time to create page: 0.050 seconds
