EMC2 running on Raspberry Pi?
Just wondering about the possibilities of having a 2 stage setup? Use a Rpi to drive the motors and ssh into it with a non-realtime device to drive the UI?
Cheers,
Rex
It works for me too, though I am not sure that the step generator is actually working properly.rexhunt wrote: Just to throw my hat into the ring... I can get mungkie's image to boot and load axis.
Also, I haven't seen any input from mungkie for several weeks.
Yes. Though I am fuzzy on the details. The is miniemc which is a web-server GUI that certainly works on the Beaglebone.Just wondering about the possibilities of having a 2 stage setup? Use a Rpi to drive the motors and ssh into it with a non-realtime device to drive the UI?
Also have a look at Rockhopper, which apparently can do this ( github.com/MachineryScience/Rockhopper ) and there is an Android App on the way from the same folks (apparently)
1. Linuxcnc won't start because of a lack of x11 server locally.(I'm sshing into the Pi as I have no monitor near my CRO)
2. Linuxcnc won't start because of some problem in the configuration not letting it be run normally(I think there is some thing with it being set up to be run in place not installed which could be a problem due to a lack of /usr/bin/linuxcnc or similar)
I'm going to have a look at option 2 today, and possibly see if I can set up Linuxcnc to use a lighter weight UI then axis.
Cheers,
Rex
Cheers,
Rex
emc2web works fine on RPi.
I'm currently using tkmini over rdesktop. It is useable provided you don't enable backplotting.
Axis can also be used as long as you disable live plot.
Cheers!
Do you have a link? I can't seem to find it with google.
How do you disable that? Is it simething in the .ini file?
