ArcEye wrote: Hi
How did you make the keypad and hook it up? I cant tell from the pictures, you cant see the backside of the buttons or anything....
It is a membrane keypad, approx 3mm thick, with the ribbon connector passed through a slot underneath it,
It is stuck to the enclosure using contact adhesive. The new key designations are printed onto self adhesive gloss inkjet paper and stuck over the originals
I got the pad from here
I am curious about the custom fascia. I have looked at these pads for another project I am working on but wanted something besides the standard 0-9 A,B,C,D etc. Is it robust enough for long term use or will the ink eventually wear off the paper?
Greg
The printed overlay is not very robust and certainly not oil or water proof. It has fared quite well during testing but I may have to experiment with laminating to try to get an overlay that lasts.I am curious about the custom fascia. I have looked at these pads for another project I am working on but wanted something besides the standard 0-9 A,B,C,D etc. Is it robust enough for long term use or will the ink eventually wear off the paper?
