- Thank you received: 240
That looks like the best bet so far, you could actually wrap it under the keypad before sticking it down to the box lid and it should protect the whole thing.Self-adhesive library film?
www.staples.co.uk/bts-offers/bts-office-...cover-film-45cm-x-1m
ArcEye wrote: I did create many more pins and try to display much more system data originally, but found that the poor little arduino just could not cope.
Miselph wrote: You can increase the bus speed to 400khz by changing a line in the Wire class (see this post )
The other thing I was wondering; I see that you are running the serial at 9600. Is there any reason this cannot be increased?
ArcEye wrote: In theory yes, but I had read a lot of reports of problems using the SoftwareSerial libraries above 9600.
I have succesfully connected an arduino to HAL using modbus protocol wich have CRC packet verification. May be you want to test it.I have also begun work on a serial packet-based protocol for reliable communication of different data types. So far I can send integers and strings with no problem. The reason for this is that I am intending to use wireless which is especially prone to data loss so I need a protocol with error checking and rejection in it; we don't want the machine doing strange things due to corrupted data now do we? It would be a good idea to adopt such a protocol regardless of connection type, as any connection will suffer some data loss from time to time.
