GIGABYTE GA-D525TUD Intel Atom D525
- BigJohnT
- Thank you received: 1176
- Thank you received: 5217
BTW if someone has the time and inclination to setup a little latency lab
We (Mesa) are willing to buy motherboards/misc for latency/compatibility testing
- BigJohnT
I just ordered a GA-D525TUD and a ASUS E35M1-M to test
- AlpineKyle
I should be able to test then as well
- BigJohnT
Well, and desk space!
Stack them up like cord wood!
- AlpineKyle
- ArcEye
- Thank you received: 758
You should be able to get the latency lower just by using the isolcpus boot time parameter.I haven't had much time to tweak it but with stock bios settings and a fresh install of linuxcnc, I'm getting latency max of 13835
wiki.linuxcnc.org/cgi-bin/wiki.pl?The_Is..._Parameter_And_GRUB2
The Intel version of this board is reported to run sub 10K max jitter after this.
running flash videos and multiple glxgears, I had as bad as 49000 base thread latency. This is in the range that I can measure with the scope on all the Atom MBs (the latency test is not to be completely trusted as it does no hardware I/O that may be blocked) The isolcpus trick seems to make the average jitter better but the worst case stays about the same
The ASUS E35M1-M was significantly better with 21000, 26000 (servo/base) thread max jitters so seems like a fairly nice fanless LinuxCNC system
