GIGABYTE GA-D525TUD Intel Atom D525
11 Sep 2012 11:22 #24157 by Rick G
Replied by Rick G on topic Re:GIGABYTE GA-D525TUD Intel Atom D525
As a side note the Dell always had a spike when starting with 8.04.
The Dell also would not run with 10.04, ridiculous latency numbers.
After building from scratch as shown on previous threads to allow the computer to run with 10.04 the initial spikes disappeared.
Rick G
12 Sep 2012 03:42 #24177 by jmelson
Replied by jmelson on topic Re:GIGABYTE GA-D525TUD Intel Atom D525
dab77 wrote:
I've always wanted to know.. can one live with the initial realtime error, if then it doesn't appear anymore during use?
Warning! That latency error is only REPORTED once per startup of the RT thread.
it MAY occur again without a message. But, in my experience, it also seems to
often not recur as a delay in the thread.
Jon
12 Sep 2012 07:52 #24183 by Rick G
Good point.
In my case I was referring to running the latency test.
Rick G
12 Sep 2012 14:54 #24195 by andypugh
Replied by andypugh on topic Re:GIGABYTE GA-D525TUD Intel Atom D525
There is a HAL parameter,( motion.servo.overruns ) that counts over-runs. If you see the RT delay fault, then it is worth monitoring that pin with a Halmeter.
If it's only 1 or 2, then perhaps live with it. If it is rising continually then there is a real problem.
14 Jan 2013 09:50 #28672 by danemc
Replied by danemc on topic GIGABYTE GA-D525TUD Intel Atom D525
i'm glad i found this thread as i was considering an amd e-350d powered board i came across but after seeing so many posts about atom cpu's i didin't know if the apu was viable. also thinking about an atom board with a d2500 (no hyperthreading but plenty of clock speed.) but may go with something more proven in the forum. is it your opinion that the asus board would be a better candidate to run stepper motors? i'm still trying to put together the pieces on what parameters effect what.
Time to create page: 0.071 seconds
