GIGABYTE GA-D525TUD Intel Atom D525
  • BigJohnT
  • BigJohnT's Avatar Topic Author
  • Administrator
  • Administrator
08 Aug 2012 17:20 #22976 by BigJohnT
GIGABYTE GA-D525TUD Intel Atom D525 was created by BigJohnT
Anyone use this Atom motherboard ? I wonder how the latency is?
24 Aug 2012 17:31 #23636 by PCW
Replied by PCW on topic Re:GIGABYTE GA-D525TUD Intel Atom D525
Ive been wondering about this as well and may just buy one to find out
BTW if someone has the time and inclination to setup a little latency lab
We (Mesa) are willing to buy motherboards/misc for latency/compatibility testing
  • BigJohnT
  • Administrator
  • Administrator
24 Aug 2012 19:29 - 24 Aug 2012 19:40 #23640 by BigJohnT
Replied by BigJohnT on topic Re:GIGABYTE GA-D525TUD Intel Atom D525
What would be involved in setting up a "latency lab"? I assume you just need a power supply and the usual attachments like mouse, keyboard, and monitor... and let rip. Oh yea hard drive, memory, DVD drive... got that stuff laying all about.
Last edit: 24 Aug 2012 19:40 by BigJohnT.
24 Aug 2012 20:18 #23643 by PCW
Well, and desk space!
I just ordered a GA-D525TUD and a ASUS E35M1-M to test
30 Aug 2012 22:04 #23782 by AlpineKyle
Replied by AlpineKyle on topic Re:GIGABYTE GA-D525TUD Intel Atom D525
Did you get it yet? Mine should be in tomorrow, if everything goes well I should have some numbers up by Saturday.
30 Aug 2012 22:36 #23783 by PCW
Yes but I did not have any DDR3 memory so that should come in tomorrow so
I should be able to test then as well
  • BigJohnT
  • Administrator
  • Administrator
30 Aug 2012 23:21 #23784 by BigJohnT
Stack them up like cord wood!
01 Sep 2012 02:00 #23819 by AlpineKyle
I got the gigabyte GAD525TUD board today and installed it into a Thermaltake Element case, took about 30 minutes to get it running. I haven't had much time to tweak it but with stock bios settings and a fresh install of linuxcnc, I'm getting latency max of 13835. After fighting two machines for way too long I am thus far excited with the results. I'll try to give more numbers tomorrow as I set this up and hopefully start cutting.
01 Sep 2012 11:58 #23826 by ArcEye
Replied by ArcEye on topic Re:GIGABYTE GA-D525TUD Intel Atom D525
You should be able to get the latency lower just by using the isolcpus boot time parameter.
wiki.linuxcnc.org/cgi-bin/wiki.pl?The_Is..._Parameter_And_GRUB2
The Intel version of this board is reported to run sub 10K max jitter after this.
04 Sep 2012 01:33 #23871 by PCW
OK just tested the GA-D525TUD (with 10,04/2.5.1), and I get much worse latency but I was pretty tough on it,
running flash videos and multiple glxgears, I had as bad as 49000 base thread latency. This is in the range that I can measure with the scope on all the Atom MBs (the latency test is not to be completely trusted as it does no hardware I/O that may be blocked) The isolcpus trick seems to make the average jitter better but the worst case stays about the same
The ASUS E35M1-M was significantly better with 21000, 26000 (servo/base) thread max jitters so seems like a fairly nice fanless LinuxCNC system
